2004 Yamoto 250cc
Old Dec 21, 2014 | 05:26 PM
Nooner965's Avatar
Default 2004 Yamoto 250cc
Atv sat for three years before I got it. Lubed the cylinder and cleaned carb. It starts and runs at idle. When I raise throttle it cuts out at first. After I try to bring throttle up several times it all of a sudden runs great. After being shut down for a while have to repeat same. Anyone have a clue what is going on with it? Also think it has MV30 carb. anyone know where I can get parts for it.
Old Dec 22, 2014 | 04:06 AM
Symptoms are rather like the choke not working. If manual, does it seem to pull out OK? If automatic, they tend to stick on choke rather than off, but I have known them fall apart inside. A slightly weak mixture may also give these symptoms, so cleaning the bowl and jets out with compressed air could help.
Old Dec 22, 2014 | 07:54 AM
Nooner965's Avatar
Thanks for reply, I have pulled carb and all appears to be clear.
Old Dec 22, 2014 | 01:34 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Sounds like a plugged pilot jet or circuit. Does using some choke help?
Old Dec 22, 2014 | 01:46 PM
Nooner965's Avatar
No using choke does not help. Only thing that helps it rev it a few times then it comes to life.
Old Dec 22, 2014 | 03:17 PM
KTM Patrol
Former Chinese POW!
New spark plug?
Old Dec 23, 2014 | 07:40 AM
Nooner965's Avatar
Plugs new.
Old Dec 23, 2014 | 08:18 AM
KTM Patrol
Former Chinese POW!
Ever heard of Seafoam? I get it at walmart.. auto parts stores have it also.. Since your quad runs sort of ok.. add 2 ozs of it to the gas tank and run it a while..it cleans out fuel systems.. Not sure what else to check since it starts easily..
Old Dec 23, 2014 | 03:34 PM
Nooner965's Avatar
Ahead of you on the S.F. And it runs normal once you throttle up a few times. Read plug after running it and it looks good.
Old Dec 23, 2014 | 04:09 PM
KTM Patrol
Former Chinese POW!
Does this carb have a vacuum slide? or is the slide pulled by a cable? does the cable go into the top of the carb?
