Head lights and brake lights won't work
Old Dec 27, 2014 | 10:21 AM
Atgarrett's Avatar
Default Head lights and brake lights won't work
I have a 2012 Polaris sportsman 500 carb. Yesterday I took the cab and pod off, when I was putting the pod back on I hooked up the cigarette lighter wrong and blew a fuse. After I hooked up it up correctly and replaced the fuse I can't get the brake lights, high beams or the headlights to come on. Everything else is working and I can't find a loose connection. I'm not sure where to go from here.
Thank you in advance!
Old Dec 27, 2014 | 10:39 AM
Check the fuse holder bottom itself. This was a common area for wires to vibrate loose,but in your case you may have melted the connections underneath when things shorted out. Plus trace wiring from the fuse holder back into the main harness along with wiring connections at the headlight,another area that was subject to shorts.All it takes is a faulty ground wire also to create problems. Tracing shorts isn't fun,takes patience and persistence.
Old Dec 27, 2014 | 10:47 AM
Atgarrett's Avatar
Thank you for the quick response. I will start tracing wires.
Old Dec 27, 2014 | 10:55 AM
Atgarrett's Avatar
It was the bottom of the fuse holder. I knew it couldn't be anything too serious. I can't thank you enough
Old Dec 27, 2014 | 11:16 AM
Where I thought it might have been. Plenty of people overlook the fuse block. Glad you found it.
3quadbob
Sep 18, 2016 09:46 PM
BGC
Utility ATVs
Oct 7, 2015 11:50 PM
cornermike
Jun 3, 2015 07:27 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
MrElussive
Dec 12, 2000 05:13 PM
