2000 polaris sportsman 335 no spark
Polaris 335 sportsman just stop running all suddenly when riding: I tested the cdi box and found to be broken; so I replaced it and having problems with the installation with the proper wires going to the proper place: Where does the black wire go to and I have a solid blue wire on my new cdi box: does that go to the ignition coil? My ignition coil only has one electrical connection that is located on the bottom of the coil!
Black wire is for the kill circuit. Should be a black wire up in the harness it connects to unless this machine is new to you and po did any wire butchering. Blue wire from the cdi goes to the coil.
Peeps
Mar 24, 2000 12:27 AM
