2000 polaris sportsman 335 no spark
Old Dec 31, 2014 | 03:53 PM
hollywoodlogger's Avatar
Default 2000 polaris sportsman 335 no spark
Polaris 335 sportsman just stop running all suddenly when riding: I tested the cdi box and found to be broken; so I replaced it and having problems with the installation with the proper wires going to the proper place: Where does the black wire go to and I have a solid blue wire on my new cdi box: does that go to the ignition coil? My ignition coil only has one electrical connection that is located on the bottom of the coil!
Old Dec 31, 2014 | 04:32 PM
Black wire is for the kill circuit. Should be a black wire up in the harness it connects to unless this machine is new to you and po did any wire butchering. Blue wire from the cdi goes to the coil.
Old Jan 13, 2015 | 04:27 PM
on the cdi wires where does the brown wire go to that came already installed with a round wire connector? does it ground to the ground on the coil mounting screws?
Old Jan 13, 2015 | 07:28 PM
Yes brown ground wire goes on lower coil mounting screw. Should be other grounds there also.
Old Jan 14, 2015 | 05:25 PM
what other grounds should be on the lower coil mounting screw beside the cdi brown wire? THANKS A WHOLE BUNCH BUDDY!!!! YOU SAVED ME A LOT OF WORK AND TIME!!!!!!!!! ROBERT HILL
Old Jan 14, 2015 | 05:34 PM
Depending on model you may have several grounds from modules,grounds from dash lights or you may have just the one ground from the cdi..
gfl0224
Jun 27, 2015 06:52 PM
yellowpolaris
Jun 21, 2015 11:13 AM
wbfjim
Jun 8, 2015 06:20 PM
FourtraxRancher
Nov 25, 2000 03:47 PM
Peeps
Mar 24, 2000 12:27 AM
