Gear selector
Old Feb 15, 2015 | 04:28 PM
rambo28779's Avatar
Default Gear selector
Got 2004 sportsman 600 twin gear selector. will not click into gear need help with exploded drawing where to locate detent and ball on machine thanks for the help
Old Feb 15, 2015 | 05:20 PM
Could be a park lockout suck(item 61) or any of the small gears behind plate #3 such as the detent pawl(#5) or gear selector (item #9). Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse Packed with grease from the factory,but can wash out over the years behind the plate.Hope this helps.
Old Feb 15, 2015 | 08:11 PM
rambo28779's Avatar
Thanks OPT that will help
Old Feb 19, 2015 | 06:39 PM
boomer's Avatar
I just rebuilt mine.. Same machine. More than likely the spring that holds pressure on the detent pawl has rusted and broke in half. I pulled mine apart to find a lot of rust and a broken spring. Pulled out all the parts and cleaned them on bench top wire wheel. Replaced the spring and gasket.. About $10.00 and repacked the cavity with grease. Now I have a positive click into each gear. Take pictures of the mechanism before you pull it apart. It actually can only go back together one way as the pawls and shave are splined. Be careful pulling off the black plastic part that has a plug going into it. That is the sensor that tells your gauge pod what gear its in. The cover itself is also plastic so be careful prying it off. The new version of the part is metal but costs almost $100. Go slow and pay attention and you will be fine if you have any mechanical ability. Not that hard of a job.
Old Feb 19, 2015 | 07:04 PM
rambo28779's Avatar
Thanks boomer have to wait till the weather warms up to fix it high of 14 here today
Old Feb 19, 2015 | 07:18 PM
boomer's Avatar
I did see a post on another forum where the writer did a step by step write up with pictures when he did his. Really helped when I did mine.
- 8 here in western pa.
Old Feb 19, 2015 | 08:20 PM
Probably saw this post or one similar to it. I've seen plenty of gear selectors like this one over the years,some even worse. Correct on taking picture/marking gears as they do go back a certain way. Make sure you seal the cover plate with a good rtv sealant to help keep this from happening again. Hard to Shift 700 Sportsman 2004 - Polaris ATV Forum
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
