Rancher problem starting
Old Feb 16, 2015 | 06:18 PM
SATXHONDARANCHER's Avatar
Default Rancher problem starting
Hi all, I've has this 2002 Rancher since new. It always had a rough idle and when it started overflowing non-stop I put a new carb on it.
OK, it started just fine. Now 2 months later I break the choke cable at the top part, no problem, I order and install a new one. Now the ATV will not start, turns and churns. To make a long story short, I took off the carb to see if there was any binding, etc. All looks well.
BUT, and here's the question: ISNT THE PISTON INSIDE THE CARB SUPPOSED TO GO UP/DOWN WHEN THE THROTTLE IS PRESSED? I took off the little side cover and made sure my throttle cable was still attached inside. While fiddling, I noticed the piston wasn't moving, not stuck because I could slide it with my finger.....
What am I missing here? I hope its not sanity.
I'm suspecting bad gas but this carb thing has got me wondering.
Old Feb 17, 2015 | 03:11 AM
No, the piston is sucked up by the vacuum in the carburettor. When the engine is not turning over, no vacuum, so the CD piston just sits there. You didn't need a new carb before, a clean out or, at worst, a new float needle would have cured the overflowing problem. Make sure your choke is working right, the little plunger should be free to move in and out in the carb, and the spring pulls the choke cable back when you turn the choke to the off position.
Old Feb 18, 2015 | 12:28 PM
Thanks, I'll check that choke plunger when I get out there again.
It was a bargain to put a new carb on this ATV. Out in the country and it never idled right in the first place. After 12 years the last thing I wanted to do was rebuild it again. I had cleaned the jets once on it.
neilbedwell
Nov 10, 2018 11:02 AM
ROWALKER
Jun 15, 2015 05:38 PM
garyt1975
Jun 5, 2015 08:53 AM
RedRancher
Jun 4, 2015 12:29 PM
1000gade
May 27, 2015 12:37 PM
