500 rebuild
Old Feb 23, 2015 | 02:16 PM
Falcon150's Avatar
Default 500 rebuild
Hi, I was thinking about rebuilding my 03 predator 500 as it is knocking. I was wondering which parts I would need to buy to rebuild it.
Cheers
Old Feb 23, 2015 | 02:20 PM
Get one of these and read through it before you even lay a wrench on it.2003 Polaris Predator 500 Service Manual PDF Download
Old Feb 24, 2015 | 03:33 AM
Falcon150's Avatar
Hi thanks for your reply. Iv got clymer and a freind who is an expert at building engines who is going to do it for me. What parts ae most likley to go and what parts should i replace while we are in it?
Old Feb 24, 2015 | 09:21 AM
The thing about engines is that you don't know what you'll need until you tear it down. Knocking can be from piston slap(worn piston /rings) lower rod bearing wear or even crank shaft bearings. Your Clymer should show you what to inspect for the most part.You may be able to get by with a new top end or you may have to completely strip the engine down and rebuild it. The most important thing to check is the rod when you pull the head and cylinder off.If it has any up and down play at the crank shaft,the lower part of the engine will have to be torn down. ebay has good prices on top end gasket kits as well as complete gasket kits if the engine has to be split. Plus for the most part Wiseco pistons are the best replacement pistons.http://www.ebay.com/itm/Tusk-Top-End-Head-Gasket-Kit-POLARIS-PREDATOR-500-2003-2007-NEW-/290881162287?pt=Motors_ATV_Parts_Accessories&hash=item43b9de4c2f&vxp=mtr http://www.ebay.com/itm/POLARIS-PREDATOR-500-Complete-Engine-Gasket-Kit-Set-2003-2004-03-04-ATV-/121564577127?pt=Motors_ATV_Parts_Accessories&hash=item1c4dd03d67&vxp=mtr http://www.ebay.com/itm/Polaris-Predator-500-2003-2007-Wiseco-Piston-Kit-4807M09920-High-Compression-/261729008444?pt=Motors_ATV_Parts_Accessories&hash=item3cf043bb3c&vxp=mtr
Old Feb 24, 2015 | 12:12 PM
NLWarrior01's Avatar
I was told when I bought my 05 that when the shop checked it over the cam bearing was a bit warn but not to worry about it. So that would be another thing to check as well as your wear limits on the cam itself. I think these engines are pretty noisy regardless, even when in pristine condition.
Good luck with your rebuild, and OPT, it's good to know that you don't always have to go with OEM for quality parts. Thanks.
Old Apr 22, 2015 | 04:27 PM
Falcon150's Avatar
Hey, Iv just installed a namura piston kit and it has fixed the problem I am just wondering how long it takes to run it in? Cheers
Old Apr 22, 2015 | 04:52 PM
Break in period is normally a couple hrs or so of low to mid range throttle. No wide open throttle during this period. Cooling off between this period of time helps on ring seating also.Allows for contraction and expansion of cylinder,piston and rings.
Beeline08
Nov 11, 2016 04:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
