2004 Polaris Predator 500 blown engine
Old Mar 16, 2015 | 12:54 PM
Dcarter199209's Avatar
Default 2004 Polaris Predator 500 blown engine
So I blew my engine in my 04' Polaris Predator 500. I bought a bottom end from someone and it seems to be fully functional. I took it to someone to see what else I needed and he said I should get a Big Bore kit in order to finish my motor. Is this all I need to put my engine back together? A big bore kit? If so which one do you all suggest.
Old Mar 16, 2015 | 02:22 PM
Several of them out there. Several on ebay on big bore kits,plus here's another place.Aaen Performance : Polaris Predator
Old Mar 16, 2015 | 06:07 PM
So all i would need to complete my motor would be a big bore kit? Any type? I see a lot of JE ones on ebay and Wisco i believe the brand is. They come with a piston, rings, and gasket. Should i worry about getting a sleeve also?
Old Mar 16, 2015 | 06:44 PM
Cylinder sleeve needs to be replaced(machine shops can do that for you) plus most good kits like Wiseco come with over size sleeves. Just my two cents I'd trust them more than any other kit.http://www.ebay.com/itm/POLARIS-PREDATOR-500-WISECO-BIG-BORE-KIT-558CC-12-5-1-/361145195391?pt=Motors_ATV_Parts_Accessories&hash=item5415ee5b7f&vxp=mtr
Old Mar 16, 2015 | 07:26 PM
Ok, thanks a lot for your help!
Old Mar 16, 2015 | 07:55 PM
Scooter86's Avatar
Knows Old ATV Questions!
Is the valve train still sound? How did it blow? If you just need a piston, then going with a BBK is generally a good upgrade for not much more cash.
Old Mar 18, 2015 | 08:58 AM
I have no idea how it blew to be honest. I was downshifting after racing a few friends and when I got to second gear I heard a loud pop. Looked down and a huge hole had been blown out the rear end of the motor. It also cracked my piston when it happened.
Old Mar 18, 2015 | 09:38 AM
Scooter86's Avatar
You may have gotten lucky, but I would check that top end closely to make sure you didn't bend a valve or anything. Also a good time for a new timing chain/tensioner.
bikedad3
Jun 29, 2015 08:58 AM
yellowpolaris
Jun 21, 2015 11:13 AM
Berjr
Jun 15, 2015 04:41 PM
Predator_500
Jun 13, 2015 03:01 PM
