Shifting problems
I own a 04 Polaris predator 500 and It will shift to 1 or N and that only? You can use the clutch or not and it won't go into 2,,3,4,5. It did this while I was riding it. What could of caused this
Hopefully it's either a shift shaft, shift drum cam or shift cam stop arm problem. At least I'd check this area first. After you remove the cover and it's still locked out of the higher gears,could be anything from a shift fork,shift drum or internal gear problem. Best to have the service manual on this one if you have to tear it down. Items #37,40,44 on the parts list. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
KimSJoh
14
Jul 18, 2015 07:20 PM
