HELP with chain adjustment on 425
Old Sep 26, 1999 | 10:01 AM
tprice's Avatar
I just installed a new rear chain on my 425 mag 4x4 and it is too tight. could someone explain an easy or the proper way to adjust chain tension. thanks
Old Sep 26, 1999 | 10:41 AM
xpoltech's Avatar
What you need to do is; take a tie down strap and compress the rear end till the swing arm and the frame are in line with each other then tighten the chain to 1/4 inch slop on the top,then tighten the bolts down and your done.(NOTE: the chain WILL look really loose that's normal)
Old Sep 27, 1999 | 10:37 AM
bdcothran's Avatar
Loosen the two bolts on axle. Insert a punch or phillips screwdriver through the sprocket hub from the side and into the axle housing. Roll the atv back slightly to loosen the chain. Forward to tighten. Remember to compress the shock and leave 1/4 inch slack when at tightest point. Tighten the bolts.
Brent
Old Sep 27, 1999 | 02:09 PM
Willie B's Avatar
I agree with Steve (xpoltech).
WillieB
P.S. Steve: I fixed the front 4wd hub engaging problem. I had two bearings swapped in the wrong place. Thks for your help.
Old Sep 27, 1999 | 10:09 PM
tprice's Avatar
thanks for the input, i took it to the dealer and the rear adjustment was "frozen" up. he had to take a pipe wrench and a cheater bar to free it up and the chain was o k, also he did not charge me anything either, it only took 5 minutes but it was raining and he stopped what he was doing to help me.(suzuki,polaris,atric cat of anderson, sc ).even though i offered to pay he declined.
Old Sep 27, 1999 | 11:45 PM
Pasqualie's Avatar
It is nice to hear of good dealers. The Dealer here in Elko Nevada is Wright Motors, and the Fellow running it, Dave Tilger, is exellent to deal with. He has helped me on mant occations. Later, Dave
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
craacker
Sep 9, 2015 04:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
goosemasterkl
Aug 23, 2015 11:36 AM
