2001 sportsman 500 ho runs rough
Old Jun 3, 2015 | 05:59 PM
skittero's Avatar
Default 2001 sportsman 500 ho runs rough
Hi guys , new to forum and do appreciate all the useful information on here !
my problem is , i just installed a new stator and regulator into my 2001 polaris sportsman 500 ho and now its running very ruff .. it bogs at idle and will not rev it just bogs out and dies .. it smells like fuel ..
i thought it was the pulsar coil gap but i do have it set to 0.025 and ive tryed several diffrent positions
my stator was fried.. the wires were all exposed and basiclly black , is it possible my cdi is done aswell?.. im after any suggestions thanks for reading
Old Jun 3, 2015 | 07:18 PM
Even though it's a 2001 HO 500,I'd check valve clearance first and the exhaust lobe for any wear. .006 intake and exhaust on valve clearance. If that checks out,may be as simple as the float sticking,worn needle and seat. If you have to pull the carb,I'd install a cheap carb kit as cleaning doesn't always help. Polaris Sportsman 500 2001 2002 Carburetor Carb Rebuild Kit Repair | eBay The floats are tricky on this model. Needs to be set where the float tab barely touches the float needle pin with out compressing it. This is how it's supposed to set.Plus here's another version of the BST40 carb that may help.http://www.advrider.com/forums/showthread.php?t=347184
Attached Thumbnails 2001 sportsman 500 ho runs rough-2471649347_b2a1a773d6.jpg
Old Jun 3, 2015 | 07:21 PM
skittero's Avatar
hey thanks for your input , i checked clearence and it was good ..
i have had the machine down for 3 days and i ride it quite frequently i put a new carb kit in 3 months ago i really dont think that its the carb but i will check
Old Jun 3, 2015 | 07:22 PM
skittero's Avatar
i should mention.. i removed the cdi , put it back in cleaned every wire i could fine , i have no spark what so ever now ...
Old Jun 3, 2015 | 07:24 PM
Again if you smell fuel,probably the float level allowing too much fuel even with the new carb kit.A lot of people had problems on these along with fuel dripping from the over flow tube. Keep us updated.
Old Jun 3, 2015 | 08:20 PM
skittero's Avatar
got no spark all of a sudden after removeing the cdi and putting it back in .. what have i done ;/
Old Jun 4, 2015 | 01:00 PM
Shouldn't have done anything by disconnecting the cdi as long as it wasn't running and plugging it back in.. Rough running could have an electrical problem waiting to happen all along and not carb related. Best to have the manual to check resistance specs on the stator and pick up coil(even if they are new) and also the coil before any electrical parts are thrown at it. May be as simple as the left control switch or ignition switch connections need to be cleaned,electrical grease applied. Good trouble shooting guides,resistance checks in the manual along with the wiring schematic.DOWNLOAD 1996-2003 Polaris Worker/Sportsman/Xplorer 400/500 Repair ...
Old Jun 13, 2015 | 02:39 PM
skittero's Avatar
im getting no ohms at the red . red/black wire ... , any ideas? the stator is new
Old Jun 13, 2015 | 02:54 PM
Red to Red/Black should be the main exciter coil wires on certain models. Resistance should be 1.9 ohms. "IF" you have a Green stator wire,try that with the Red/Black.Should show around 446 ohms. Plus all these wires should show infinity when metered to ground,should not zero out. Possible the replacement main exciter coil(main stator itself) is faulty. Wouldn't be the first time I've seen that happen.
Old Jun 14, 2015 | 02:22 PM
skittero's Avatar
well that sucks .. what a waste of money , ill try to get another one i guess
