What happened in the rain?
Old Jun 19, 2015 | 10:35 AM
wannabe32's Avatar
Default What happened in the rain?
Left my 06 Linhai 300 out in the rain for a few days to get "rinsed off" and it wouldn't start. Ended up replacing the battery and got it started for a few seconds and then die with and without throttling. Sprayed some carb cleaner and then starter fluid in and was finally able to get it running up to the garage where I let it idle for almost 10 minutes. Thought all was well but it still runs real rough, pops, and stalls out. Almost feels carb/fuel related but it had been running well with 0 issues up to this point. Any ideas or should I just let it dry out for a few days? thanks
Old Jun 19, 2015 | 01:45 PM
Scooter86's Avatar
Knows Old ATV Questions!
Probably got some water in the gas or some of the electronics got wet. 8 would start by draining the tank and carb of all the fuel and put in fresh.
Old Jun 20, 2015 | 07:38 AM
MPDano's Avatar
The sun works wonders in drying electronics out. If you have a compressor, I would remove plastics, blow out anything electronics. Let it dry out in the sun. Drain all gas and oil and put new. If it we're me, I would also remove the carb and remove bowl and clean it all out. General maintenance should get it going again.
I try not to leave my ATV's directly in the rain. Harbor Freight has inexpensive tarps to cover your ATV if it needs to.
Old Jun 24, 2015 | 10:29 AM
TLC's Avatar
TLC
Spray some water proofing ignition spray on every wire and terminal you can see.
Old Jun 24, 2015 | 02:16 PM
MPDano's Avatar
Good post, gotta get me some of this. Except, we're pretty dry out here in SoCal and all my toys stay under the patio cover.
Old Jul 7, 2015 | 10:41 AM
wannabe32's Avatar
Just left it to dry in my garage but it still is acting up a lot. Need to give it lots of gas to get it going and really rev it in neutral before it will not stall. Even then the engine really hesitates sometimes when attempting to accelerate and will sometimes sputter and backfire before totally bogging down. Sometimes it will recover and sometimes it won't and stalls out. Should I keep trying to get fuel with injector cleaner through or do I need to get to the carb? Where is it and how hard is it to clean out? Thanks!
Old Jul 7, 2015 | 11:30 AM
Scooter86's Avatar
Yes, you need to drain the carb and gas tank, then put in fresh gas. Usually they will have a drain at the bottom of the float bowl, but you may need to remove the bowl. I had one of these issues and didn't completely drain the bowl. It took a lot longer to clear the bad gas than I would have thought.
Hopefully that is your issue because at least it is a cheap fix.
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
awer1968
Sep 8, 2015 11:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
