ignition wiring?
Old Jun 26, 2015 | 01:15 PM
Ragtop's Avatar
Default ignition wiring?
My Grandson's Chinese quad has some wiring problems. It ran until my son unplugged the tether to check it and hasn't done anything since. I've tried jumpering the tether but that didn't help. I also found the ground wire to the starter housing was bad and replaced that. Now the lights work properly and it cranks over but it seems like there's no spark. It has a 110 cc Honda or Honda clone engine. Where would one look for a wiring diagram for the ignition?
Old Jun 27, 2015 | 03:04 AM
There are many different wiring diagrams, unless you know the make of Quad you probably won't get one. Did you try with the tether wires disconnected? Some work by stopping the engine when the two wires are joined. Take the plug out, connect the lead and lay it on the head to check if you have a spark. With all that trying to start you could have "wet the plug."
Jmuddin284
Jan 19, 2026 07:16 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Hatrackr
Aug 11, 2015 09:03 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Unzzy66
Jul 11, 2015 10:01 PM
