kickstart gears
Old Jun 28, 2015 | 02:50 PM
yz guy's Avatar
Default kickstart gears
Anyone know how to line up the kickstart gears for a 1985 230 suzuki quadsport I replaceed the sidecase gasket and the kickstart gears wont kick the motor over anyone with any info would be greatly appreciated
Old Jun 30, 2015 | 10:05 AM
rotaxtwin's Avatar
There are little tiny dots stamped in the outer part of the kicker gear shaft that line up with the kicker lever. On the inside there are tiny stamped dots on the kicker gear and the kicker shaft. Just line up all the dots and you're good to go.
Hope this helps. If not pm me and I'll try to copy the pages out of the manual for you.
Old Jun 30, 2015 | 11:02 AM
yz guy's Avatar
Thanks ill try it up this afternoon any luck with the clutch issues
Old Jun 30, 2015 | 12:18 PM
rotaxtwin's Avatar
I haven't fooled with it in a couple days. Maybe later today. I'll post how it goes. Good luck with the kicker. The dots are small so you'll have to look close. Let us know how it goes.
Old Jun 30, 2015 | 12:20 PM
rotaxtwin's Avatar
Almost forgot there are also dots on the gear inside that are on the case half near the clutch. If you get them all lined up all you have to do is put the clutch cover back on.
Old Jun 30, 2015 | 04:48 PM
yz guy's Avatar
If I line the dots touching each other the outside gear is on the dead spot ? I think im looking at them now and thats how I think they go just dont want to reseal the case and be wrong again
Old Jun 30, 2015 | 06:22 PM
rotaxtwin's Avatar
I think that's the way it should look. Just put the cover back on and install a few screws and test it with the spark plug out and use your hand to make sure. I can look at mine and let you know.
Old Jun 30, 2015 | 06:55 PM
yz guy's Avatar
Is there anyway you can email me the info from the manual I just cant get this thing rite if you can its Jeffhoule1984@gmail.com idk thanks
Old Jun 30, 2015 | 07:06 PM
rotaxtwin's Avatar
I'll make copies of the pages tomorrow and email them to you. They will be in pdf format.
Old Jul 1, 2015 | 07:23 PM
rotaxtwin's Avatar
Did you get the pages? If so how did you make out?
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
