Sport Quads Discussions on sport quads.
2006 KFX 400 starting and gear issues
Old Jul 5, 2015 | 03:18 PM
Jkfx400P's Avatar
Default 2006 KFX 400 starting and gear issues
Ok so last fall I bought myself a 2006 kfx 400. It ran flawless all winter through early this summer. Recently, it has been having starting problems. When I start it, it does not sound normal and it sometimes takes a little to get it started. It is starting to get worse so I don't want to ruin it... On the other topic, when I drive low second gear (haven't driven low in any other gear), it tends to make a knocking and clicking sound kinda like something is bouncing around. But it only does it in low second gear. Any help or advice is appreciated
Old Jul 5, 2015 | 03:40 PM
Jkfx400P's Avatar
Update: just took the beast for a spin and I turned it off to look at fish... Tried to start it and it was wasn't kicking in to start. It was just making a ringing noise and nothing else. I waited a few minutes then started it and it fired right up. Is it the starter? I'm not too advanced so I don't know if it could be that.
Old Jul 5, 2015 | 03:51 PM
nachop's Avatar
Yes, it does sound like your starter, probably the solenoid. As far as hard starting, you may need to do a valve adjustment. If you don't have a service manual, you need to get one.
Old Jul 5, 2015 | 08:45 PM
Jkfx400P's Avatar
is a valve adjustment something that I should get a pro to do it? Or is that something that is actually really easy and simple to do?
Old Jul 5, 2015 | 10:33 PM
nachop's Avatar
It depends on how mechanically inclined you are and what kind of tools you have. As I stated previously, you need to get yourself a service manual if you plan on hanging on to your KFX. A valve adjustment is a pretty simple thing. It is usually more troublesome getting to the valves due to everything that has to be removed to get to them. Do a search on YouTube. You should be able to find something, then you can decide if you want to try it on your own.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
buckshit
Sep 24, 2015 08:49 PM
txkevin
Sep 21, 2015 02:02 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
1000gade
May 27, 2015 12:37 PM
