No spark. Test results. Need help
Old Jul 19, 2015 | 08:38 PM
Ripinandtearin's Avatar
Default No spark. Test results. Need help
so i picked up a 110cc chinese quad (same motor as the bikes, honda clone) for $75 knowing it needed a new top end. put in the new piston,cylinder,head. ive now discovered there was more to it. electrical problems. so i grabbed my multimeter and went to town. tested at the CDI and have my results but not know what to make of them. hoping someone can help
all tests were done at the harness side of the CDI connection (5 pin)
Kill switch to ground (resistance)- infinite
AC ign power to ground - 312 ohms
Timing trigger to ground - 117 ohms
Ign coil to ground- 1.8 ohms
AC ign power to ground while cranking - 32v
Timing trigger to ground while cranking - .1v but jumps 2.1 when i let off the starter
Ign coil to ground with CDI installed and cranking - 0.0v jumps to 18.1 when i let off starter
any help appreciated. any other suggestions to check? thanks in advance
ultangler
Nov 30, 2024 01:35 AM
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
scorpiankill
Sep 10, 2015 09:14 PM
