ATV wont run (wiring diagram)
Old Jul 26, 2015 | 08:14 AM
Tadej Dylan Vuzem's Avatar
Unhappy ATV wont run (wiring diagram)
Hello. I am having an issue with a 200cc china quad I bought recently.The motor just wont start. It wont make any sound when I press the start button.. I realy have no clue what to do.. Maybe something is wrong with the wires, so I made Today a wiring diagram, can anybody see what is wrong?
Old Jul 26, 2015 | 11:07 AM
Zrock's Avatar
Super Quad Patrol
Have you checked the obvious battery and fuse's?
Old Jul 26, 2015 | 02:55 PM
yes I have.. The fuse was burned but I replaced it, the battery is ok
Old Jul 26, 2015 | 05:58 PM
Dammar's Avatar
Default Atc won't run
Are you activating brake switch while pressing start button ??
Old Jul 27, 2015 | 02:42 AM
Nice diagram, it should help others, especially if you can give us a makers name. Do you get a click from the solenoid? If not, put a test lamp across the green/yellow wire and the brown wire going to it, press the start button and see if the lamp lights, if it does you have a faulty solenoid. If it doesn't, connect the lamp to the green/yellow and the battery, the lamp should light on either the pos or neg. If it doesn't light on one of them, the fault is with this circuit, brake switch, relay? etc. If the green/yellow is OK the fault is in the brown, so trace that back to see if the switch is faulty.
Old Jul 27, 2015 | 04:55 AM
The brake switch was broken, so I connected the two wires directly.. Now the brake light is shinig
Thank you.. It is a Bashan 200cc ATV... I will try your recommendation with the lamp like you said, and reply the results.. Now that you mentioned it, yes the solenoid is clicking... what does this mean?
Old Jul 27, 2015 | 07:26 AM
MPDano's Avatar
Low Battery, Bad Starter or Engine is seized. Put 12 volts directly to your starter motor while spark plug is out.
tombrown14
Nov 10, 2015 06:48 AM
tombrown14
Aug 26, 2015 07:30 AM
Atvnewb88
Aug 19, 2015 02:22 AM
Atvnewb88
Aug 13, 2015 06:48 AM
tweeder
Jul 5, 2015 01:57 PM
