yamaha bruin 350
Old Aug 8, 2015 | 04:07 PM
blessedn09's Avatar
Default yamaha bruin 350 cranking issues
Hey guys and gals,
I have a 97 yamaha bruin and the oil cooler line busted causing the oil to dump out. un Fortunantly it was at night and wasnt able to see it before the bike died. It has fire and compression. What else could it be timing? Fuel? Oil pressure? That is keeping it from cranking again.
Last edited by blessedn09; Aug 8, 2015 at 04:15 PM. Reason: more specific on title
Old Aug 9, 2015 | 03:07 AM
I would be very surprised if you do have compression. Most air cooled Quad engines suffer from piston and/or piston pin seizure when run short of oil, it can wear the cam/followers excessively too. Anyway, the piston starts to pick up on the bore and the result is seized/broken rings, a "milled" piston, and a big gap that compression can leak out of. Incidentally it must "crank" or you couldn't check for a spark, it just doesn't fire.
buddieboy
Dec 9, 2016 05:50 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
Sep 23, 2015 06:23 AM
