brand new stator has 7 wires. 2 are not connected
Does the connector still match up? If so, I would just mount the stator and give it a try without putting the cover on. If the connector doesn't fit, then use your old one to match up wires. I found that chinese wire colors are all over the place without a standard.
I never has luck with chinese stators. I tried to use one on my KTM dirtbike as the old oem one was bad. Not only did it not completely fit correctly without some cast mods, it didn't work. I ended up buying a good used oem one off ebay and it worked perfectly.
I found out what they were..they're for gearbox indicators..thanks for the help..I'm trying to rewire the whole atv now..almost have it put back together but i will keep updated,because I'll need help..thanks man for the advice.
cody500ho
14
Aug 14, 2015 05:03 PM
