brand new stator has 7 wires. 2 are not connected
Old Sep 12, 2015 | 10:07 AM
johnny1982's Avatar
Default brand new stator has 7 wires. 2 are not connected
Hello everyone! I am new to repairing chinese atvs..i am replacing the stator,wire harness,spark plug coil,rectifier, and solenoid . My 5 wire stator came and it has 7 wires and 2 of them aren't connected on the inside part of the magneto. The wires that aren't connected are red with green stripe and solid black..I'll try to attach photos..please help
Old Sep 12, 2015 | 01:46 PM
MPDano's Avatar
Does the connector still match up? If so, I would just mount the stator and give it a try without putting the cover on. If the connector doesn't fit, then use your old one to match up wires. I found that chinese wire colors are all over the place without a standard.
I never has luck with chinese stators. I tried to use one on my KTM dirtbike as the old oem one was bad. Not only did it not completely fit correctly without some cast mods, it didn't work. I ended up buying a good used oem one off ebay and it worked perfectly.
Old Sep 13, 2015 | 07:41 PM
johnny1982's Avatar
Smile
I found out what they were..they're for gearbox indicators..thanks for the help..I'm trying to rewire the whole atv now..almost have it put back together but i will keep updated,because I'll need help..thanks man for the advice.
cody500ho
14
Aug 14, 2015 05:03 PM
ScopeZ_
Jul 28, 2015 01:44 AM
toonces
Jul 23, 2015 02:21 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
