200cc clutch issues
Old Sep 27, 2015 | 05:41 PM
tysonbully's Avatar
Default 200cc clutch issues
So i bought a quad with a no good engine. so i got a new engine for it. Exact same engine. It was half stripped down.
So i rebuilt it with new gaskets.
Got it running but tried to put in to gear and no movement. So i took the clutch off and had a look and put another clutch i had from old engine and now the wheels wont stop turning.
Am i missing something?
should it have 6 or 7 friction plates?
What does the pin that goes in middle of the clutch and the clutch lever do?
I have had it in and pushed on it and seems to do nothing?
any help would be really appreciated. thanks
this is the engine fitted to atv.
[IMG][/IMG]
this is same style clutch i have fitted.
[IMG][/IMG]
Old Sep 27, 2015 | 06:03 PM
Should have a clutch arm or shaft that puts pressure on the center pushing the plate and springs in which take tension off the clutch plates. The outer pressure plate and fiber and metal plates should just spin allowing gear change or at a stop takes pressure off the gear shaft assembly and drive sprocket. Plates may just be frozen and stuck together if sitting for any length of time keeping pressure on. Take it out and keep working the clutch and trying to shift if you can. You may end up freeing up the plates. If it doesn't help then you may have to remove the plates,clean the metal friction disks and fiber plates and reassemble or get some new fiber plates.
Old Sep 27, 2015 | 06:20 PM
tysonbully's Avatar
I have had them out and put spare set i had. The shaft part that goes in middle of clutch doesnt seem to do anything.
I have pushed on it and it doesnt move.
Should the friction plates be tight or loose?
Old Sep 28, 2015 | 02:30 AM
With no pressure on the clutch plate and springs,the clutch "pack" as they call it should be tight. Only when spring pressure is release by compressing the springs and center plate should the plates be "loose"
ghost civic
Jan 15, 2020 07:43 AM
Tadej Dylan Vuzem
Jul 27, 2015 07:26 AM
Mikesohio
Jul 26, 2015 10:51 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
