Front wheels squeaking on Honda 350 Rancher (2003) but there aren't any grease fittin
Old Nov 8, 2015 | 04:30 PM
Matthew-Becca Morgan's Avatar
Default Front wheels squeaking on Honda 350 Rancher (2003) but there aren't any grease fittin
I've read on here that the Hondas don't have grease fittings, but since I obviously have a lubrication problem with the front wheels I'm wonder what I need to do.
I read someone say just to spray lithium grease, is this sufficient? Where should I spray?
Is there a youtube video or something on how to lube the front wheels/a-arm?
I'm new to ATVs. I want to learn all the good maintenance practices to keep this running as long as possible.
P.S. I've heard rumors that there is a foot shift lever you can get for the electric shift system. Is this bad for the transmission? Haven't heard anything conclusive.
Thanks!!
Old Nov 8, 2015 | 05:54 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Are you sure its the wheel and not the shock bushing dry?
Old Nov 8, 2015 | 06:11 PM
It doesn't make sound when I put weight on the shocks only when I roll it forward. Would this be the case of the shock bushing was dry?
Old Nov 8, 2015 | 07:46 PM
atv-wheeler's Avatar
Hmm it could be the brakes that are squeaking not the wheels it self.
Old Nov 8, 2015 | 09:18 PM
Scooter86's Avatar
Knows Old ATV Questions!
Could be worn brake pads, could be wheel bearings, if it is a 4x4, could be part of that system.
Old Nov 9, 2015 | 02:59 AM
2x4 Honda 350s have rubber shielded "sealed for life" bearings so you would have to take them apart, they can get dry. 4x4 350s are a source of trouble on the front wheel bearings as the outer races get to turning in the housings, all the 4WD Hondas are the same, this leads to excessive play at the wheel rim. For some unknown reason 350 steering knuckle assemblies are three times the price of 300s, 400s, 420s etc. Lift the front wheels up, check for play and take the squeaky wheel apart, checking brake shoes, and hub assemblies, you can put grease round the 4WD bearings whilst the knuckle assy is off the driveshaft.
Old Nov 9, 2015 | 06:32 PM
Loved
Community Favorite
Has brakes been replaced? sometimes an brake spring can be installed upside down an spring will rub brake drum
bigred20653
Sep 19, 2015 02:11 PM
patrick.oc123
Sep 15, 2015 02:45 PM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
bigred20653
Aug 31, 2015 12:41 PM
