Ba150 no start
Old Nov 25, 2015 | 10:56 PM
MarkH0789's Avatar
Default Ba150 no start
Hey guys I'm new to the forum so forgive me if this is a old topic. Had a baja 150 atv given to me cause it wasn't running. Cleaned the carb and put a battery in and got it running. Found a few parts missing such as the spring for the diaphragm in the carb and a broken ignition switch. Found a spring that was perfect and the thing ran great. I decided to cut the ignition switch out as it was broken and missing the key and replaced it with a
3 prong rocker switch from a parts store. Now the darn thing won't start. Cranks and I have power and lights but just won't kick over. Would that rocker switch have anything to do with it? In kinda lost and not looking to put too much money into this thing. Any advice would be great.
Old Nov 26, 2015 | 09:14 AM
MPDano's Avatar
Maybe look at your old switch and take it apart to see how it operates. You most likely don't have it connected correctly or that new rocker you bought doesn't work the same way. Usually 3 prong rocker switches use the 3rd prong to power a built in light in the switch.
Old Nov 26, 2015 | 12:48 PM
MarkH0789's Avatar
Did just thAt and found that the accesory wire wasn't powering as it was lighting the switch. Rewired and runs perfect now thanks for the help!
Flyboy03051
1) Engine problems..
Nov 12, 2015 11:11 PM
1ArmBandit
Nov 6, 2015 06:19 PM
tomlang63
Nov 3, 2015 10:55 AM
Buckshot1
Oct 27, 2015 08:10 PM
