Speedo quit working
Old Dec 16, 2015 | 07:37 PM
GregM's Avatar
Default Speedo quit working
Have a 1996 Polaris sportsman 500 600 + miles. Noticed the speedo was not working. Tried a search but nothing for this older model. Looked at cheap part diagram but did not see anything to check. Any help appreciated. Was working 2 days ago.
Old Dec 17, 2015 | 07:42 AM
Cable driven speedo driven off the gear case. 95% of the time it's the small "key" that breaks inside the gear case adapter that's the problem. You can first unhook the cable at the gear case,place in neutral with the rear wheels of the ground and turn the wheels. If the inside of the adapter doesn't turn,the key is broken. Plus you can see if the cable might be frozen from the gear case to the speedo.That's the other common thing that can happen. Item #44 is the key. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse They aren't cheap. Here's one on ebay.3280217 Polaris | eBay
Old Dec 17, 2015 | 09:46 AM
GregM's Avatar
Thanks I will check it out. This one has nothing to do with the AWD as the others do correct since it is manual not electric?
Old Dec 17, 2015 | 09:52 AM
No doesn't have anything to do with the awd on these old models thank goodness..
bbradford
Oct 10, 2015 09:52 PM
mpcwizzard
Oct 5, 2015 08:53 AM
stcspiderman
Oct 4, 2015 01:01 PM
Sw00p
Sep 24, 2015 02:50 PM
Nosparkpolaris
Sep 20, 2015 04:21 PM
