Cotton or foam air filter?
Old Jan 17, 2016 | 02:11 PM
TaoTao110D's Avatar
Default Cotton or foam air filter?
Hey everybody, just trying to get a consensus as to which everyone prefers on their atv's/go karts/mini bikes etc. My daugthers TaoTao 110 atv came with a cheap looking cone filter that doesnt want to stay on the carb regardless how much I tighten the clamp. Looks like a blue cotton K&n clone.
I want to get a better quality, hopefully slightly larger filter media cone filter, either K&N oiled cotton or Uni dual layer foam, but not sure what everyone prefers on atv's. Ive always had good luck using K&n cotton filters on my cars, but have never had any experience with foam at all.
K&N, or Uni air filter?
What size base would I need to correctly fit the carb on this 110cc gy6 clone? 38mm? 42mm? XXmm?
Old Jan 18, 2016 | 08:00 AM
MPDano's Avatar
I use Uni on all my ATV's. Measure the diameter of the carb air inlet and that will give you your size.
Old Jan 18, 2016 | 08:13 AM
Scooter86's Avatar
Knows Old ATV Questions!
Foam for all offroad situations save sand/dunes where the cotton does a better job.
Old Jan 18, 2016 | 08:23 AM
This is like an oil post when you mention air filter preference also. Uni imo makes the most sense also,but there are die hard K&N lovers out there that swear by them. I've had to repair engine damage where neglected K&N filters were used and never cared for them except for street use. You stop up an Uni with dirt and engines will just choke down from lack of air,but clean and oil the filer and it's up and running again. No grit will get past it to eat up pistons. K&N if kept up with cleaning and oiling along with a good outer sock I guess would be ok. I'm just biased against them from what I had to go through.
Old Jan 18, 2016 | 08:40 AM
hugemoth's Avatar
I use these. Quality and construction appear to be as good as Unifilter.
http://www.ebay.com/itm/Black-Foam-38mm-45-Degree-Angled-Air-Filter-110cc-125cc-PIT-DIRT-BIKE-ATV-Quad-/151488341079?hash=item234568a457
Old Jan 18, 2016 | 09:38 AM
Zrock's Avatar
Super Quad Patrol
i agree on the k&n.. hate on off road use...
i have the same filter on my 110. i just spray it with a k&n filter oil and use rim grease on the connection. never had a sign of dust in engine
Old Jan 19, 2016 | 09:35 AM
LT80's Avatar
LT80 Expert
Foam. Period. Everywhere.
My daughter was sponsored by Velocity filters (K&N type).
Curtis Sparks was her motor builder and said "she'll learn". In the meantime, a new piston was installed every 2 races. Sparks sells a foam filter to go over a stock foam filter. That says alot in my book.
Old Jan 20, 2016 | 03:51 PM
TaoTao110D's Avatar
So I guess a foam Uni it is! Thanks everybody!
johnpma
Dec 31, 2016 07:27 PM
TaoTao110D
Feb 23, 2016 10:48 PM
Lora Holland
Feb 6, 2016 09:43 AM
shore
Jan 14, 2016 02:03 PM
