!999 Warrior No Start
Old Jan 19, 2016 | 01:54 PM
eddie1218's Avatar
Default !999 Warrior No Start
I have a 99 warrior 350 that will only start with ether. When it does start it runs rough and wont take full throttle. We have a new top end rebuild on it, new carb kit, carb was cleaned atleast 3 different times, timing is good and valves are good. have a new one way clutch and new stator also....Any suggestions on where else to go from here?
Old Jan 19, 2016 | 05:26 PM
Fasteratv's Avatar
Sounds like it isn't getting fuel, or not enough.....maybe old fuel. Might verify your petcock isn't stopped up...remove fuel line from carb, open petcock, have a glass jar handy and capture a fuel sample, might have water in it.... and see how the fuel flows. If all good, re-attach fuel line ( might install a small fuel filter ), open the carb drain to ensure fuel flow. Are you sure the float is set to Yamaha spec?
Old Jan 19, 2016 | 05:29 PM
eddie1218's Avatar
It's new gas and the fuel does flow through it freely. I didn't check the floats do you know the factory specs by any chance?
Old Jan 19, 2016 | 07:46 PM
Fasteratv's Avatar
11.4-13.4mm.
Old Jan 19, 2016 | 07:48 PM
Fasteratv's Avatar
11.4-13.4mm. You might want to download a manual...$5 on most sites. It is invaluable....
joe2k
Nov 23, 2015 12:26 PM
m2cyclone
Nov 11, 2015 10:05 AM
Buckshot1
Oct 27, 2015 08:10 PM
pfcfreeman8
1) Engine problems..
Oct 27, 2015 07:50 AM
