Honda, Rancher will not go into Reverse at all
Old Jan 24, 2016 | 06:01 AM
Bryn176's Avatar
Default Honda, Rancher will not go into Reverse at all
I have a 2006 Honda, Rancher 350. I can up shift and down shift, both by electric and by hand, but I can not get it into reverse at all. Either by hand or electric. I got 2 codes, first was code 3 then code 8. I did change the Angle Sensor, still no Reverse. I bought this brand new. Was working real good plowing a deep snow. Oil level is good.
Can it be because of wet wires ? Maybe a bare wire ? I have it parked in a heated garage, I have to check for a bare wire.
Any help ? Has this ever happened to any one ?
I have over 30 inches of fresh snow to plow, so need help fast.
Than You
Old Jan 25, 2016 | 07:53 PM
Fasteratv's Avatar
I don't know enough about this to help you but here's a google link.
http://www.google.com/search?q=Honda%2C+Rancher+will+not+go+into+Reverse+at+all&oq=Honda%2C+Rancher+will+not+go+into+Reverse+at+all&aqs=chrome..69i57j69i60&sourceid=chrome&es_sm=93&ie=UTF-8
Old Jan 26, 2016 | 02:53 AM
If you can't get reverse by the emergency lever, it is a mechanical problem. A cable runs from the handbrake lever to a lever at the back of the engine. This stops you getting reverse until the red button is depressed and the LH handbrake applied. If you are lucky, the cable may just require adjustment. A lockout switch is fitted so the electrics won't try to engage reverse without the handbrake mechanism engaged, but the emergency lever would still work if the switch was the problem. This doesn't explain the fault codes, so you may have another fault. It could be a loose "star wheel" or broken selector mechanism, but this usually occurs in all gears.
Old Jan 31, 2016 | 07:35 PM
papa hogg scoot's Avatar
Loved
Community Favorite
If you was just riding around in deep snow..I would check the rear and bottom an see if reverse wire got pull off by the snow is common here with we live....there an single wire connector that connects to reverse switch right above skid plate in rear center
Old Jan 31, 2016 | 07:36 PM
Loved
Community Favorite
Also stick could have or packed snow could have clotted up motion of reverse lever arm also an rear center bottom of engine
cornermike
Feb 9, 2019 10:46 PM
yooper66
Jan 17, 2016 09:24 AM
viponderosa
Dec 28, 2015 05:34 PM
viponderosa
Ask the Editor
Dec 27, 2015 12:48 PM
