No start
Old Feb 9, 2016 | 02:35 PM
maveikfe's Avatar
Default No start
Hi I have a kesea skyhawk 250 that will only start with starting fluid has new carbs coils cdi plugs UT spray starting fluid and will start .So anyone might know of something? Thank you
Old Feb 10, 2016 | 02:43 AM
It isn't going to be electrical, so could be compression or carburettor. New carbs have to be set to suit your machine unless you bought it/them from the bike's manufacturer. I find it is always easier to clean out the old carb than set up a new one. As for compression, do a test, if you have low compression, check the valve clearances, no clearance means they need adjusting.
Old Feb 10, 2016 | 06:56 AM
shovelryder's Avatar
Has to be a fuel issue.....you know for sure carbs are getting fuel to the cylinder? Can you try to flood it on purpose with your hand over the air intake?
Old Feb 10, 2016 | 07:47 AM
maveikfe's Avatar
They where both right from the manufacturer sealed bags when I got them. After I got them and it still didn't start they made a cross over pipe for it so I got that so instead of two carbs it's now a one carb but that didn't work either lol. I will put the the carb back on it tonight and see what happens. Thanks
Old Feb 10, 2016 | 09:45 AM
Zrock's Avatar
Super Quad Patrol
As said above check the compression and adjust valves. Then set up the carbs and verify choke is working properly.
Old Feb 10, 2016 | 10:10 AM
maveikfe's Avatar
Thanks will do that.
Old Feb 13, 2016 | 07:03 PM
maveikfe's Avatar
Ok I did adjust the valves today and got it going but it will only run with the choke full on now . So I tried to adjust the carb but just with the choke on it runs great lol . any help?
Thanks
Old Feb 15, 2016 | 11:34 AM
MPDano's Avatar
Choke on running is a clogged idle jet.
Old Feb 15, 2016 | 12:14 PM
maveikfe's Avatar
But would that do it to 2 brand new carbs?
Old Feb 15, 2016 | 12:19 PM
I think your new carbs are jetted too small........if not clogged. I clean all new carbs before I install....Youd be shocked at the debris.
