choke
Old Feb 27, 2016 | 11:14 AM
mmh102's Avatar
Question choke
I have a 2003 Honda trx 250 te. I just cleaned the carb and put it back together it is running great idles great. now it wont start with the choke on.when i start it without the choke then pull the choke it dies.
Old Feb 27, 2016 | 07:50 PM
Fasteratv's Avatar
I'm not understanding....if it starts without the choke...and idles ( when warm ), why are u applying the choke?
Old Mar 2, 2016 | 12:15 PM
mmh102's Avatar
We'll I was jut trying to get it ready for the spring season. When I try to start it after it sits overnight it still won't start with the choke on. How would I figure out if the choke Is working properly.
Old Mar 2, 2016 | 03:00 PM
Choke is a simply a butterfly valve that opens and closes by the lever. Buttery valve closed(choke on) shuts down air into the carb for a richer mixture.Honda OEM Parts - The Worlds BEST supplier for Original Honda Replacement Parts Discounted Honda Motorcycle, Dirt Bike, ATV, SxS, and Scooter
Old Mar 2, 2016 | 04:30 PM
Fasteratv's Avatar
^^^^ Good pic and description OPT. That particular type choke rarely fails, but what I was saying is to ensure the choke ( butterfly ) had full movement...and linkages were tight. In reality, may not be the problem anyway.
- So it started well with the choke before you cleaned the carb?
- Since you cleaned the carb ( if cleaned correctly ) maybe you don't need
full choke? I have rebuilt carbs that required full choke when cold, then
after rebuiding the carb, needed very little choke when cold.
- Next time you try to start it, go ahead and use full choke, but also add a
tiny bit of throttle ( air ), say about 1/16" open on the throttle. See if it
fires up. If it fires up. Next time try it with about 3/4 choke. Manual chokes
seem to be different on each ATV ( even an identical ATV ), some require
more choke, some less choke, and some... no choke unless its really
cold out.
- You might also pull the spark plug, clean it and reinstall it before trying to
start it.
Hopefully we helped you here.
Old Mar 2, 2016 | 05:33 PM
mmh102's Avatar
Maybe it just hasn't been cold enough to need the choke. It has been warm plus I have kept in a heated garage. The reason I was concerned is I cleaned the slow jet and thought that I may have damaged it. It was completely clogged. So I had too turn the idle screw several times to get the idle to slow down. Before I cleaned the carb it would idle real high with the choke on. So I thought it should do the same after I cleaned it. thanks
Old Mar 2, 2016 | 08:28 PM
Fasteratv's Avatar
Change or clean the spark plug....and try it without any choke....see what she does....
merryman
Apr 26, 2016 04:39 PM
Timbo2500
Jan 15, 2016 11:11 PM
mmumm
Dec 25, 2015 10:13 AM
Polarisman1123
Dec 15, 2015 07:15 AM
CharlesAL22
Dec 1, 2015 09:43 AM
