Converting my 03' Big Bear 400 to 4WD
Hey all. I'm new to the forums and I recently came across some good almost free parts to convert my 03' Big Bear 2wd to 4wd. Process seems pretty easy up to the point on actually plugging the the electrical's to the SERVO in front DIFF. Instead of rewiring my ATV's system etc I may just run new wire to the servo to use a manual lever switch to engage servo. This would probably be easiest to do.
What do you all think? This would save me cost of having to buy new harness etc.
Some of you may ask why not sell the ATV and just buy one. Well honestly it would cost me way more plus this ATV only has 340 miles.
Does the 2wd gear case even have an output port for the driveshaft for a front diff? if not, there is no way to convert it without swapping in a drivetrain from a 4wd quad. Its like converting a 2wheel truck to 4 wheel, it can be done, but by the time you are done, you will have a lot of money invested in a vehicle not designed to operate that way, and a factory 4wd is beefed up to handle the extra weight and torque coming from the driving front end. sounds like the quad is in great shape, you would be better off selling it and buying a four wheel drive model, I know that's not what you want to hear, but it would be a lot less of a headache that way.
Apparently I was wrong and it wasn't easy. The engine is not the same as I could not remove that "PLUG". So the whole project was a bust. It would have been easy though but no point if I couldn't get that shaft in.
The only exception to that is if you get a GOOD deal on either a complete parts bike or all of the parts together that you need to do the swap, AND you do the work yourself...
I was in the same boat with my 04 Bruin 350. Already had the bike as a 2wd, but stumbled on an awesome deal for ALL of the parts needed (and then some) from a 4x4 to do the conversion. Did a full engine swap, harness swap, etc. It was all bolt-on, but it was a good bit of work. I don't regret it at all though!
Later on I bought another 4x4 Bruin that turned out to have a bad top end on the engine. I still had the 2wd motor sitting in the garage, so I was able to rob the top end from it to throw on the newly acquired 4x4 and it it back in working condition, so in the end it all worked out
https://youtu.be/OrDuXF_56D8
