Warn winch doesn't work
Old Apr 12, 2001 | 03:03 AM
kindsambo's Avatar
I have a brand new dealer installed Warn 2500lb winch but every time I need it in the mud the dam* thing won't work until the bike sits for 30 min and dries. What can I do to fix it? Got stuck twice now and the winch let me down.
Old Apr 12, 2001 | 10:37 AM
fishbones's Avatar
This is just a shot in the dark but check.
1. Make sure the wire kit is for the right warn/atv setup. There is a difference in the 2000/2500 as well as the ATV you are using.
2. Have the setup (wire) rechecked, you may be able to fix, but have dealer look again.
3. If installed incorrectly, warn can fry the entire electrical system.
4. I didn't get the 30 minutes stuff, but it doesn't sound like a wet thing, more of a amperage thing to make it work. Hey soak it and see what happens, but do the first 2 things first, you don't want to fry.
Old Apr 12, 2001 | 11:11 AM
Yamanshee's Avatar
My brother-in-law had the same problem with his Warn 2500. In the end he had to send it back to Warn for warranty repair. I believe it was in the solenoids seals. Water was getting into them and it wouldn't work. He heard from his dealer that Warn had trouble with a run of winches that all had this problem. His new one works great no matter how wet/muddy it gets.
Old Apr 12, 2001 | 01:38 PM
girlatvr2's Avatar
has there been a recall using the lot code?
Old Apr 12, 2001 | 02:46 PM
thenewfiebullet's Avatar
I was having the same problem with my winch. Try spraying Wire Dryer, or some other kind of contact cleaner on all the electrical conections, especially the in/out switch. It worked for me.
Old Apr 12, 2001 | 08:00 PM
kindsambo's Avatar
Thanks for the replies. Will spray my connections and check with the dealer for a recall. I sometime run in heavy mud here in Nova Scotia and getting stuck is part of the fun...as long as one has a winch that works. Thinking now I might have been better off getting the much CHEAPER superwinch.
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
sara durrant
Jul 6, 2015 05:32 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
