Spark Plug - Tightening
Old Mar 26, 2016 | 02:41 PM
Timbo2500's Avatar
Default Spark Plug - Tightening
After my recent top end rebuild I tried to screw in my spark plug and noticed the threads were screwed up. I could only hand tighten it about four revolutions before I had to use a wrench. I am going to order a Helicoil thread repair kit but in the mean time was curious how far I should screw in the spark plug? I have attached a picture of where it is now. Is there a way to know by sight? I'm not sure if it is in far enough? I appreciate any guidance...
Old Mar 26, 2016 | 02:59 PM
Mauler5's Avatar
Maybe pull on the pull cord a little easy and at the same time see if oil comes out where you think it might not be connecting
Old Mar 26, 2016 | 03:04 PM
Before you go to a helicoil or time sert you might want to use a thread chaser with a little grease on it to see if you can clean up the threads.You can get these at most auto stores.
Old Mar 26, 2016 | 04:45 PM
Timbo2500's Avatar
Thanks OPT. I will definitely try both. When I inspected the threads they looked fine so hopefully I can forego the Helicoil.
Old Mar 26, 2016 | 09:00 PM
Fasteratv's Avatar
Fasteratv's Avatar
Old Mar 26, 2016 | 09:41 PM
Kymco 450i's Avatar
Yes those do work, over the years I have saved many threaded holes in heads from serious thread damage with a chasing tool. If the threads look decent then you will probably be good, the heli-coil should be a last resort.
Clint Reynolds
Apr 1, 2016 01:25 PM
hammerit2
Mar 24, 2016 05:37 PM
GoinCrzyWanaCom
Mar 23, 2016 04:19 AM
INEEDHELPPLZ
Mar 22, 2016 06:40 AM
razman_07
Mar 13, 2016 04:06 PM
