400ex chain problem
Old Mar 29, 2016 | 07:55 PM
Chris.400's Avatar
Default 400ex chain problem
This isn't a problem with the chain, but with the tightener ring thing. I loosened the 4 allens. I have tried channel locks, 2 screw drivers, and smacking it with a hammer and a flat head. The damn thing will just not budge. I tried prying apart the housing where the bolts clamp down on AND trying to move it at the same time,, still nothing. Help please, I really wanna ride this weekend.
Old Mar 29, 2016 | 10:13 PM
jgar's Avatar
Remove the 4 pinch bolts then use a large flat head screwdriver as a wedge to spread the swing arm from around the carrier.
There were times when I would have to spread the swing arm then use a punch and hammer to get the carrier moving. Dont just hit the carrier with a hammer. They will crack rather easily.
I have also used a plumbers chain spanner.
Old Mar 30, 2016 | 10:59 AM
Chris.400's Avatar
I tried that, even with 2 people. And I pretty much ruined the carrier last night, so I just ordered one from Superatv. Will not get to ride this weekend, but oh well. I discovered last night it also needed new bearings, so this is a good investment. I also found another problem. I can not get the axle lock not to budge at all. I used tons of penetrating fluid, and a large pair of channel locks, and the thing will not break loose!! Getting fed up with this thing, this is the first 400ex that I have ever seen with this much stuff overtighened and not lubed properly.
Old Mar 30, 2016 | 04:40 PM
jgar's Avatar
Axle nut is reverse thread and IIRC there is a clip on the axle hidden by the nut that has to be removed. My axle nut wrench was a 3' pipe wrench. When you re assemble and are done wrap the axle nut in electrical tape because they are known to loosen up. I would also put a small amount of anti seize in the swing arm where the carrier goes. It helps with rotating carrier to tighten the chain long after the project is done.
Old Mar 31, 2016 | 08:17 AM
Chris.400's Avatar
I did not know they were reverse thread. thanks. And I decided to get a whole new carrier, a double row one. And I am going to grease it up real nice before i put it all in. Thanks for the help man
Jul 10, 2016 08:42 AM
grangerboy
Mar 29, 2016 10:21 PM
Norcat
Mar 29, 2016 10:04 PM
grangerboy
Mar 29, 2016 12:10 PM
Timbo2500
Mar 26, 2016 09:41 PM
