burned out 2 regulators
Old Apr 15, 2016 | 01:17 AM
50over's Avatar
Default burned out 2 regulators
I'm working on a 99 arctic cat 500 4x4. Original rectifier had melted wires and was not charging the battery. Replaced it with a new one from Rick's and was fine for one trip. After that it developed a misfire, by turning on headlights miss would go away. Soon afterward it would misfire anytime you would accelerate. I unplugged the rectifier and the misfire is completely gone. The rectifier tested bad on one leg and stator tested fine, no shorts and producing proper voltage. My question is do I have a bad short, or did I get a bad rectifier.
Old Apr 15, 2016 | 08:41 AM
Could be a faulty regulator,but you can do a generalized stator test by checking that the stator charge coil wires have some resistance between each other and no wire shorts to ground. Best way is to go through the tests the manual shows. Here's a free service manual link. Hope it works. Zippyshare.com - 99 ATV Service Manual-S.pdf
Old Apr 15, 2016 | 08:47 PM
50over's Avatar
I couldn't open link, probably my computer. Stator tested good, getting voltage real close to normal, and could not find a short to ground. Thinking about getting another aftermarket rectifier and using it more often and see what happens. Hate to spend close to $300.00 for a A.C. rectifier.
Old Apr 22, 2016 | 04:00 PM
50over's Avatar
Default rectifier part no.'s
Is the Arctic Cat part #'s 3430-072, 3430-037, 3430-016 all the same rectifier? Some part dealers don't know about the 037 part #.
Old Apr 5, 2020 | 10:33 PM
Travis Terrell's Avatar
Default Not fireing
I pluged in my battrey n my regulator started to smoke n i cant affoard all the high tec stuff it dosnt fire at all now i replaced the regulator wat else did it burn
Old Apr 13, 2020 | 01:10 PM
adalah's Avatar
+1
95scramblerruben1033
Dec 7, 2014 08:17 AM
Scott267839
Oct 5, 2011 05:18 AM
Simtech
Feb 3, 2010 04:24 PM
fourtraxhonda300
Nov 29, 2009 10:45 PM
pmerwin
May 8, 2005 03:56 PM
