Rubicon low gear
Old Apr 12, 2001 | 06:24 PM
muzzy3's Avatar
When a rubicon is shifted into low the transmission shifts into D2 at the same time. D2 is for maximum torque, however it also means less engine braking.Is there a way to dissable the switch to D2 so it will remain in D1? would this do any harm?
Old Apr 12, 2001 | 10:17 PM
TEXMud's Avatar
When the Rubicon is in Low, you do not have a choice of D1 or D2. There is no "super" low or anything.
Old Apr 13, 2001 | 07:17 PM
muzzy3's Avatar
I know what you mean. There is no choice. What I want to know is if there's a way to keep it from switching to max tourqe when shifted into low. The steep hills of New England require engine braking and brakes. My rubicon holds back better in high d1 than in low.
Old Apr 13, 2001 | 10:33 PM
MTNMAN's Avatar
Hey, Muzzy that seems very strange to me because my low range makes the rubi creep down any steep grade, and high D1 going down the same grade goes about 3 mph faster and Ive been down some real steep stuff. Just my 2 cents worth, dont hardly ever use the brakes. Happy Trails!!!!!!!!
Old Apr 14, 2001 | 12:02 AM
goattrotter's Avatar
That is very strange because I can not believe how slow it will creep in low,if start going down a steep incline from a stop it will not let it go faster then 4 kph.
Old Apr 14, 2001 | 12:05 AM
TEXMud's Avatar
In low the engine braking should be better. Throw it in ESP and it will almost stop mine.
Old Apr 18, 2001 | 12:25 PM
RubiconBob's Avatar
Same as the others: D2 does not have the engine-braking that D1 has, but put in LOW, and it's as good as D1, if not better! Have you actually tried it, or are you basing that comment on D1 vs D2 engine braking, knowing that Low automatically means D2?
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
bigbear350quad
Sep 11, 2015 12:40 PM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
