Shifter not working properly
Old Jun 7, 2016 | 10:53 AM
colt1126's Avatar
Default Shifter not working properly
Hello everyone! i have a 98 Kawasaki prairie 400 2x4 and it won't shift into high gear but i will run in low neutral and mostly reverse if i hold it in sometimes but I'm not real sure how to fix this problem summer is here the shop will charge me an arm and a leg and will take lots of time any ideas on how to fix this issue will be greatly appreciated
Old Jun 7, 2016 | 12:37 PM
Fasteratv's Avatar
See if it will shift into high with the engine turned off ( maybe idling too high ). Also, probably a linkage adjustment, have you tried adjusting the linkage?
Old Jun 12, 2016 | 03:08 PM
colt1126's Avatar
sorry for the late response but i tried to shift it into high with the engine turned off but it still won't go there is a bottom plate in which it has to go into in order for the tie rods to shift i figured it might be the tie rods but i haven't tried adjusting the linkage yet which I'm not really sure how
Old Jun 12, 2016 | 07:06 PM
Fasteratv's Avatar
You might google the "how to" to adjust the linkage, or purchase a repair manual. The manuals are usually $5 at tradebit.
Old Jun 12, 2016 | 07:22 PM
Kymco 450i's Avatar
There is a linkage adjustment on the Praire and it is quite simple to adjust. Havent done one in quite a few years but should pop up in a search. There are two parts that need to line up and each has a hole that needs to line up to each other. It is under the plastic around the shifter itself. If I remember correctly you put the shifter in a certain position then adjust the linkage adjustment until the two holes align. I can't remember the fine details but it is easy to do. You might also have a bent shift fork inside and that will take some serious work to fix. People have a habit of forcing the shifter or trying to shift with machine still rolling, it has to be dead stopped! Tyr searching "Nyroc's ATV website" they are experts on Kawasaki machines, that is where I found a lot of my info when I owned a Praire 300.
Proudpapa3
Technical and How-To Articles
May 25, 2017 01:47 PM
Proudpapa3
Mar 24, 2016 01:38 AM
Swatj15
Mar 18, 2016 04:51 AM
