Alright so I went to a small local store and the guy there said I could use this oil(picture down below). The oil says its for a snowmobile and I need oils for a 1999 Polaris trailblazer 250 which has a delegate reservoir. Can I use this oil?
Maxima is a good synthetic brand oil.Yes you can use it as its designed for injector or premix applications.Won't hurt to use it in your Trailblazer. You can even use it just as well in your two stroke weed eater. Main thing is to try not to mix several different brands as some oils don't mix well with others or so they've said over the years. Really haven't had any problems with people using two different types oil in the two stroke oil tanks.
