Polaris Ask an Expert! In fond memory of Old Polaris Tech.An area where experts in their field will answer non-general questions about your Polaris ATV. "old polaris tech" and other experts will answer your questions as they have time.
ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE POLARIS FORUM. Basic or General questions posted in a expert section will be moved!
Silver one is the regulator and most likely the problem if it's not charging back to the battery.Plus make sure the connection are good.You can check the yellow wires coming from the stator that lead to the regulator connector to rule out a stator charge coil.With an ohm meter should show some resistance between each yellow stator wires with no yellow shorting to ground. If this checks out then it's pretty safe to say the regulator is faulty. Several oem regulators on ebay plus a cheaper aftermarket one that might be worth looking at if it has some kind of warranty.4011925 Polaris | eBay
