2008 polaris 800 rzr charging problems
Old Jun 23, 2016 | 09:47 AM
bwalker2's Avatar
Default 2008 polaris 800 rzr charging problems
I need to know which electrical item to replace is it the silver one or the black one cause the battery won't charge and the fan stays on a long time.
Is it the ecm or the silver one
Old Jun 23, 2016 | 12:23 PM
Silver one is the regulator and most likely the problem if it's not charging back to the battery.Plus make sure the connection are good.You can check the yellow wires coming from the stator that lead to the regulator connector to rule out a stator charge coil.With an ohm meter should show some resistance between each yellow stator wires with no yellow shorting to ground. If this checks out then it's pretty safe to say the regulator is faulty. Several oem regulators on ebay plus a cheaper aftermarket one that might be worth looking at if it has some kind of warranty.4011925 Polaris | eBay
dpri8977
Jun 22, 2016 06:30 PM
bwalker2
Jun 21, 2016 04:51 AM
bwalker2
Jun 21, 2016 03:21 AM
Sbillingssr
May 30, 2016 06:47 PM
