Is this a loose timing chain?
Old Jul 8, 2016 | 04:24 PM
Stevireno's Avatar
Default Is this a loose timing chain?
Hi all, first post... I've been lurking a while, and was hoping for a pro to listen to my motor and give me their thoughts...
I got the atv with a spare motor, the spare motors chain is tights as a drum, the atvs chain is much looser...
File upload is limited to 5 mg, so I've attached a link to the video in my google photos...
Thanks, its 1990 350 warrior, I just got it, cleaned out the carbsm adjusted the valves, and I'm afraid to run it with this noise...
https://goo.gl/photos/tWTx54FCtF5ZCKtr6
Steve
Old Jul 9, 2016 | 09:05 AM
Stevireno's Avatar
Default Anybody?
I'd love some help if anyone can spare a moment...
Steve
Old Jul 10, 2016 | 07:12 AM
ag2560's Avatar
If you take off the cam cover and you can feel play in the timing chain it needs to be replaced. You shouldn`t have any slack in it at all.
Old Jul 10, 2016 | 07:37 AM
Stevireno's Avatar
OK, thanks, it definitely has slack and the adjuster seems to be extended all the way out. I'll replace it.
Steve
Old Jul 12, 2016 | 04:05 PM
Mindless's Avatar
Take off the timing chain tensioner and see if it is all the way out. It's hard to diagnose problems via video but my z400 was making a similar noise so I bought a manual adjuster off ebay so I could ride it before the season ended and it worked great. I promptly changed the chain over the winter though. I only recommend the manual tensioner as a band-aid not as a fix....if the chain is stretched then it needs changing.
barge bait
Jun 28, 2016 08:56 AM
donw
Jun 20, 2016 03:19 PM
Mudwaller88
Jun 18, 2016 07:31 AM
Chris Grieco
Jun 9, 2016 01:37 PM
cswiger
Apr 29, 2016 10:22 AM
