Head Bolt Torque Eton 50TXL ???
Old Jul 26, 2016 | 03:03 PM
can-amsledder's Avatar
Default Head Bolt Torque Eton 50TXL ???
Does anyone know the Cylinder Head Bolt Torque on a Eton 50TXL??
Thanks
Old Jul 26, 2016 | 05:02 PM
Same basic engine as the Polaris 50. Engine parts(cylinders,heads,pistons) can in fact interchange with several different brands. http://www.ebay.com/itm/Dinli-50cc-4...FSkYph&vxp=mtr Torque on the Polaris 50 is 14 foot pounds on the head nuts.
Old Jul 28, 2016 | 03:16 PM
Thanks
I looked and looked and couldn't find anything for the model I have. Other models range from 14-21 from what I've seen.
Old Jul 28, 2016 | 03:26 PM
See if this pdf manual helps.https://www.google.com/url?sa=t&rct=...UfT6sA&cad=rja
Old Jul 28, 2016 | 03:44 PM
Yep, that's pretty much what what I had found.
What's the difference between the cylinder head nut and cylinder head bolt?
Cylinder head nut
28-30 N.m (20.7-22.1 lb./ft)
Cylinder head bolt
20-30 N.m (14.8-22.1 lb./ft)
Old Jul 28, 2016 | 04:13 PM
Just a guess,but looks like they have the cylinder stud torque along with the head nut torque and they both look like they're reversed. If the head nuts are like the ones Polaris uses which I think they are, I wouldn't go much over the 14 foot pounds.
Old Jul 28, 2016 | 04:18 PM
I kind of figured that....after I hit the post button.
It doesn't make any sense to have the stud torque less that the bolt.
Thanks for the help.
Old Jul 29, 2016 | 08:09 AM
LT80's Avatar
LT80 Expert
14 ft lb = 168 inch lbs.
I find it scary to go to 120 inch lbs.
It is a 6mm stud, right?
Old Jul 29, 2016 | 08:58 AM
Eton,Aeon(Polaris),Dinli and a couple others shared basically the same engine.Polaris had 6mm studs and had a 14 pound head torque reading for the 50 and 90cc models. Look at chapter 2,page 21 on this manual.2003 Polaris Scrambler 50-90 Sportsman 90 Predator 90 Service Manual[1] - Documents
Old Aug 4, 2016 | 05:05 PM
Well the head gasket came today, so now I have another question. The gasket has a raised impression around it. Does it matter which way it goes?
