1985 Polaris Trail Boss idling issue.
Old Aug 3, 2016 | 05:36 PM
85trailboss's Avatar
Exclamation 1985 Polaris Trail Boss idling issue.
I just got an 85 Polaris trail boss, in quite good condition. So, the situation i'm having is that the quad wont idle without full choke. i ride it around the yard without choke, runs fine, but instantly dies if you let off the throttle. cleaned the carburetor - did nothing, checked for air leaks, seems to be none, i just don't know what to do. i am quite fed up right now so any advice would be helpful. -85trailboss
Old Aug 3, 2016 | 05:38 PM
1ArmBandit's Avatar
if its never been apart my money would be on crank seals
Old Aug 3, 2016 | 06:21 PM
What is the compression reading,plus how did you check for air leaks?
Old Aug 4, 2016 | 07:55 PM
The compression is 154 with 4 pulls, i might have high compression pistons, in which my knock at idle will happen because im using shitty 87 octane gas. i need to get over to the gas station to get some premium.
Old Aug 5, 2016 | 06:27 AM
154 psi on a 250.. That's higher than what a new one was straight out of the crate...
Old Aug 6, 2016 | 06:32 PM
Exclamation
Update, nothing has changed whatsoever. it vibrates at low rpm/idle and wont stay idling without choke. ive noticed that once it warms up, it wont idle with choke on at all, and when i flip the choke to off, the rpms go up about 1000, then drop back down to stall. how would i know that my crank seals went?
Old Aug 6, 2016 | 06:35 PM
Leak down test can show if crank seals, or a head or base gasket,intake manifold or even a case could be leaking. Main seal that would leak on these is the one behind the drive clutch.
arc burn
11
Jul 23, 2016 01:14 AM
Rluckie
Mar 7, 2016 10:53 AM
Clayton Ault
Feb 23, 2016 12:02 AM
JOE3824
Feb 1, 2016 02:52 PM
Burrlok
Sep 24, 2000 12:09 AM
