Clutch Problems
Old Aug 11, 2016 | 06:26 PM
PerryLee6532's Avatar
Default Clutch Problems
I have a Kawasaki Bayou 300, I just replaced the clutch kit however my machine will not move either forward or reverse. It feels to be shifting. Sure hope there is someone with advice. I'm lost at this point.
Thanks
Old Aug 12, 2016 | 02:53 AM
Which clutch did you replace? Did you check that the other one was OK? Have you re-set the adjuster after putting the cover back on?
Old Aug 12, 2016 | 01:22 PM
Thanks Merryman
it was the secondary clutch that was replaced. I will check on the other advice you provided.
thanks again
Old Aug 13, 2016 | 02:16 AM
If adjusting it doesn't work, and you are opening up the case to check the centrifugal clutch, check that you have assembled the secondary properly while you are in there.
DennisZ
Jul 28, 2016 09:47 AM
Andre Konstantinov
Jul 20, 2016 11:54 AM
Jugglethese
Jul 17, 2016 01:51 AM
Gt40mki
Jul 16, 2016 10:16 AM
mikesjunk
May 30, 2016 07:31 PM
