how to lift for cleaning
Old Aug 20, 2016 | 10:02 AM
ram1000's Avatar
Default how to lift for cleaning
how do I lift my atv on to its rear wheels for cleaning the frame
Old Aug 20, 2016 | 01:10 PM
Just do it. If it has a carburettor, turn the fuel off, and a tank above half full is liable to leak out of the filler cap or vent. I use a hoist, but two people can lift the front end of a 500 Foreman skywards, put the handbrake on first if you are lifting it "by hand". It sits on the back plastics but is not all that safe, so a prop may be needed.
Old Aug 20, 2016 | 04:49 PM
Kymco 450i's Avatar
I have a wand with a curved end for my power washer, that squirts water up into the frame when I just stand there, found the tip on e-bay. Do have to be carefull as the first couple times I used it I sprayed water up into my own face.
Old Aug 21, 2016 | 12:16 AM
greg74's Avatar
If you have a winch, you can use that to lift the front. I have done that myself before and a friend of mine used to do it all the time to clean out his Grizzly underneath.
Old Aug 21, 2016 | 08:22 PM
Kymco 450i's Avatar
My other option is a set of drive up ramps for my car, they will get the machine up high enough to spray underneath.
merryman
Aug 17, 2016 01:52 AM
bkb72
Aug 12, 2016 09:29 AM
Strickland84
Aug 10, 2016 03:30 PM
