Linhai 300 ATV wont start
Old Aug 30, 2016 | 12:41 PM
melissacruz's Avatar
Default Linhai 300 ATV wont start
Linhai 300 Scout wont start. When it started having issues it would run for a bit then quit. Checked the spark and there was non. It ran okay for a while then quit and repeated the same problem again. I unplug the coil wire and checked it with a volt meter and I blew a 5 amp fuse - then after replacing it with another now it won't even crank, no headlights nor does the instrument panel light up and I cant seam to find any other fuses. I think I really goofed something up and what could that be? Perhaps a diode or module? Any suggestions? Melissa
Old Aug 30, 2016 | 02:51 PM
DirtDevil101's Avatar
You blew a 5 amp fuse testing the coil with a tester??? Really??? Did you possibly do something else?
Is the battery good?
Old Aug 30, 2016 | 03:45 PM
Default Battery and fuses are good but puzzled
The battery checked out okay and the fuses are good. Checked for power to the fuse bus and there is 12 volts there however no power to instrument panel. What would cause the instrument panel and no headlights to not operate? In my analysis of what could have taken place during my stupid test, I could have inadvertently sent back some high voltage like a reverse spark through the system that shorted or destroyed some component.
Old Aug 30, 2016 | 07:51 PM
Default A simple fuse that looked okay was bad.
My last attempt to replace all the fuses with brand new ones; even though they looked okay, solved the electrical problem.
With a visual inspection a fuse that looked okay had a hairline crack causing cut out issues and sometimes it would run and some times not.
After replacing all 4 fuses with brand new ones I am confadet everything is okay. Problem solved. Melissa
Old Aug 31, 2016 | 09:29 AM
Zrock's Avatar
Super Quad Patrol
what side of the coil did you test?
Old Aug 31, 2016 | 11:16 AM
excellent...good job!
Old Aug 31, 2016 | 12:41 PM
Default Tested the coil and blew a fuse
Two issues; a bad fuse and a frayed butt connection. Since the coil on the Linhai 300 ATV is located in a very hidden area on the right side of the frame up underneath the wheel well which is difficult to tell what wire was which. I'm not sure which one I might have inadvertently touch but when I did I saw a few low amp sparks and then there was nothing there after. I knew I blew the 7.5 amp fuse and checked the others which I thought looked okay. Previously I had over looked one of the 15 amp fuses which had a hairline crack and replaced it with a new one along with all the others.
Also located up in front of the neck of the bars in the wire harness is a factory open butt connector. The two wires were made up of two different types of non ferrous metals crimped together. The bad connection appeared to have corrosion and frayed wire from vibration and movement and so I re-spliced and soldered that. It now runs like the day it rolled off the assembly line. A mater of fact; there all now built for the assembly line and not meant for servicing by the customer nor of anybody, period.
Thank you, Melissa
towersink
Feb 28, 2016 02:54 PM
Kazjag500
1) Engine problems..
Feb 11, 2016 09:50 AM
MaxAZ
25
Aug 30, 2000 10:40 PM
gardner10
Feb 29, 2000 10:38 AM
FALCON
Jul 20, 1999 09:55 PM
