lights flicker
Old Feb 22, 2016 | 09:04 AM
towersink's Avatar
Default lights flicker
To anyone that can help! I recently purchased a used 07 polaris trail boss 330. It had some issues runability wise. I discovered the ecm was fried and replaced it also found starter solenoid not engaging and replaced it as well. Battery is junk but can pull start to run. Now my lights flicker head and taillights and trans cooler fan runs spuratically and temp light comes on. What could be left to cause this issue?
Old Feb 22, 2016 | 09:28 AM
Start with a new fresh battery first. Has to have constant 12 volts for lights to operate properly along with constant power going into the ecm that controls the charging,fan,hot lights,etc. Hopefully battery will solve your problems.Plus running without the battery for an extended time can possibly cause damage to electrical components along with that new ecm module.
Old Feb 22, 2016 | 09:56 AM
towersink's Avatar
That was my plan this weekend. I know the ecm controls charging but do these have a stater or magneto that actually charges the battery? Also with the cooler fan could that possibly be the thermistor going bad, the reason I say that is because of when I first got it the fan would run even with the key of which I assume was related to the ecm being fried. But since I replaced the ecm it still comes on spuratically with the temp light on also.
Old Feb 22, 2016 | 10:23 AM
Magneto triggered ignition,that's why you're able to pull start it,but charging voltage from the stator has to go to the ecm then to the battery. With no battery it just screws the system up,triggering different reactions from the ecm,some may be false.. Yes it does have an oil cooler thermistor that can short out,BUT replace the battery first! Then you can trace down any other remaining problems. Process of elimination!
Old Feb 27, 2016 | 08:20 PM
towersink's Avatar
Default trail boss 330
Opt changed the battery and that solved the light flickering issue but the trans cooler fan still stays running what might possibly be my issue now the thermistor
Old Feb 27, 2016 | 08:41 PM
Usually the thermistor shorts when this happens. Pull the connector and ohm out the thermistor wires.If they zero out,it's shorted.
Old Feb 27, 2016 | 11:14 PM
towersink's Avatar
Volt meter stayed at ol on all points of thermistor but I unplug thermistor and fan still runs can I jump it to confuse it to make fan not run
Old Feb 28, 2016 | 04:30 AM
Unplugging the thermistor and the fan keeps running is probably because the fan section the ecm may have shorted out again when you ran it with the dead battery. The ecm replaced the older thermistor module and incorporates it along with charging,etc all in the ecm. Just my two cents on this,I'd check that the ecm is at least charging 14 volts back to the battery. If so,at least that part of the ecm is still good. I'd run the fan on a toggle and kick the fan on when under loads or slow driving for extended periods of time. To be honest with you most people never have heard their fans kick on these oil cooled machines unless they got super hot. I hardly ever got one hot enough to have the fan kick on one that I had in the shop for service.Plus there are oil cooled machines out there that don't have fans to begin with. Either toggle the fan or if you're really picky about this,spring for another ecm. There is a fan circuit breaker under the front panel in a sealed pouch,but don't think it would be the cause of the continuous fan operation,but worth a look see. Just check that it has power in and out of the breaker. Item #2 in the parts breakdown. http://www.cyclepartswarehouse.com/f...07&fveh=284171 Plus to make matters worse seems like the thermistor (4010934) is NLA at most online places.. Plus with the thermistor designed to kick the fan on at 260 degrees,off at 240,another good reason to just toggle it.
Last edited by old polaris tech; Feb 28, 2016 at 05:02 AM. Reason: circit breaker and thermistor sensor
Old Feb 28, 2016 | 02:54 PM
towersink's Avatar
Unplugging the thermistor and the fan keeps running is probably because the fan section the ecm may have shorted out again when you ran it with the dead battery. The ecm replaced the older thermistor module and incorporates it along with charging,etc all in the ecm. Just my two cents on this,I'd check that the ecm is at least charging 14 volts back to the battery. If so,at least that part of the ecm is still good. I'd run the fan on a toggle and kick the fan on when under loads or slow driving for extended periods of time. To be honest with you most people never have heard their fans kick on these oil cooled machines unless they got super hot. I hardly ever got one hot enough to have the fan kick on one that I had in the shop for service.Plus there are oil cooled machines out there that don't have fans to begin with. Either toggle the fan or if you're really picky about this,spring for another ecm. There is a fan circuit breaker under the front panel in a sealed pouch,but don't think it would be the cause of the continuous fan operation,but worth a look see. Just check that it has power in and out of the breaker. Item #2 in the parts breakdown. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Plus to make matters worse seems like the thermistor (4010934) is NLA at most online places.. Plus with the thermistor designed to kick the fan on at 260 degrees,off at 240,another good reason to just toggle it.
Thanks OPT I'll checkout the breaker if all else fails put a switch in. Thanks for your help
spacex
21
Jan 18, 2016 07:19 PM
1ArmBandit
10
Dec 17, 2015 05:16 PM
crkola
Dec 11, 2015 01:47 PM
Doctapitt
Dec 4, 2015 10:45 AM
