Brake flush.
Old Sep 2, 2016 | 08:55 PM
WilliamBos's Avatar
Default Brake flush.
Getting a list together of my needs for spring maintenance.
Want to flush the brake fluid, I hear the name mityvac used often.
Can I use them to suck fresh fluid through the system?
https://www.rockymountainatvmc.com/p...ke-Bleeder-Kit
Old Sep 3, 2016 | 05:34 AM
Best way to flush a brake system is to use a mityvac. Even quicker if you use shop towels,rags to soak up fluid in the master cylinder first,fill it with fresh dot 4 and start bleeding at the rear caliper first until fluid is clear then move to the front right.
Old Sep 3, 2016 | 03:14 PM
WilliamBos's Avatar
Thanks OPT.
Old Sep 13, 2016 | 01:16 AM
switzomatic's Avatar
Ditto on OPT's thread. I bought one of those manual (pump) 8 qt suck-o-matics from Northern and love it. On brakes, I suck all the fluid out of the master and top off. Then use my power bleeder on all the lines until I get fresh fluid through them. Also works great on all other fluids. Plenty of hose to get down any dipstick/fill tube to suck the old stuff out.
Old Sep 13, 2016 | 11:48 AM
DirtDevil101's Avatar
I have the mity-vac and it works...however, the best way to bleed is up as that is the way air wants to go anyway...drain old fluid out, find clear hose that fits very snug on caliper bleeder, attach other side to syringe that holds ample fluid and squeeze...when master is 1/2 full close bleeder and test for pressure...a different path if you don't want to spend the $40-50 on the pump...
Old Sep 13, 2016 | 12:37 PM
1ArmBandit's Avatar
the reverse method makes way more sense to me but ive never tried it, where do you find a syringe that big! lol
Old Sep 13, 2016 | 01:24 PM
turkey baster...
Myridge
Mar 25, 2017 02:00 PM
Libertynow
Aug 14, 2016 05:29 PM
Libertynow
Technical and How-To Articles
Aug 13, 2016 01:55 PM
Fastest1
Aug 10, 2016 08:37 AM
