Front axle removal
Old Sep 15, 2016 | 10:14 AM
dwoodfin's Avatar
Default Front axle removal
2009 Outlander 500, busted inner front right boot. I've been unable to find any information on youtube or anywhere on the best procedure to remove the front axle. I can get it out...just not sure on what is the best (easiest) method. Looks like the brake caliper and brake rotor have to be removed?Does the outer joint have to come apart to replace the inner boot? If so, then I guess that the band on the outer boot will have to be removed. I didn't order a replacement for that, if it can't be re-used.
Old Feb 18, 2017 | 04:55 PM
grizzsara's Avatar
Did you run across this one at
I haven't had the chance to watch it, but it sounds like it could be able to help you.
Also, if you've had to replace the boot, check out American CV for good aftermarket parts. I know they have later years (think 2014) - may have earlier years as well for boot kits.
WilliamBos
Sep 13, 2016 01:24 PM
Shanebroska
Sep 12, 2016 10:51 AM
doc0810
Sep 11, 2016 07:00 PM
jasarc
Aug 30, 2016 12:27 PM
wchamblin
Aug 24, 2016 03:20 AM
