650 kawasaki prairie starting problems. Clicking solenoid. 2003
Old Jan 11, 2017 | 08:30 PM
Anthony Di Salvo's Avatar
Default 650 kawasaki prairie starting problems. Clicking solenoid. 2003
2003. 650 kawasaki prairie sokenoid is clicking when pressing start button. Changed solenoid same result. Is there another contact. Help please
Old Jan 12, 2017 | 03:31 AM
When the solenoid clicks but the engine doesn't turn over, nine times out of ten it is worn starter motor brushes. Checking is dead easy. Put a 12v test lamp between the live lead from solenoid to starter, and earth. Switch on, press start button, if the lamp lights your starter needs removing and checking, if the solenoid clicks but the lamp doesn't light, the solenoid is faulty. On the old 300s etc, there were two starter solenoids, one was worked by the neutral gear switch, but it clicked when you turned the ignition on, not when you pressed the start button. Not sure if the 650 is the same.
Old Jan 16, 2017 | 07:18 PM
MrSummit's Avatar
Every time mine clicked was due to a weak battery.
How old is battery?
Have u had it tested?
How many miles on atv? Gives a rough estimate how much starter may have been used.
