400 kodiak
Old Apr 29, 2017 | 07:55 AM
Dbob7's Avatar
Default 400 kodiak
On my 03 kodiak 400. The red reverse light is on while in neutral. It stays on when I shift into forward. Then it Boggs down like it would going into reverse. I checked the linkage and it looks tight and fine. I took it off and manually moved it and got the light to go off but can't get it to stay off. What can I do? Thanks
Old May 1, 2017 | 03:56 AM
Seems like your gear position indicator switch unit is faulty. On some bikes it is on the bottom of the gearchange lever, on some the end of the shift drum in the engine. Often they can be taken apart and cleaned out.
pjr710
May 24, 2017 09:56 AM
Kevin_Leduc
May 11, 2017 09:44 AM
Dbob7
Apr 28, 2017 10:28 PM
Guzziman53
Apr 27, 2017 11:51 AM
Ratliff2017
Apr 25, 2017 04:32 PM
